Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Use the point of a spudger and tweezers to gently scrape up and remove all the old front camera adhesive.
Use a spudger wrapped in a microfiber cloth and one drop of high‑concentration (>90%) isopropyl alcohol to clean up any adhesive residue from the front camera recess.
Allow the alcohol to dry completely before continuing.
Remove the large clear liner from the front camera adhesive and gently place it into the recess.
Use a spudger to press down firmly on the adhesive to secure it.
Slowly peel up and remove the remaining liner.
If your replacement front camera has a protective cap, carefully remove it.
With the cable facing the right side, lay the front camera into its recess and press it into place.
Use your finger to press down and reconnect the front camera press connector.
Slide the top corners of the front camera bracket under the lip in the frame and press the clip in to secure it.
Use a Torx Plus 3IP screwdriver to install the 5.0 mm‑long screw securing the front camera bracket.
