Pioneer Elite PRO-RO6U Optical Drive Replacement
  1. Pioneer Elite PRO-RO6U Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 2, image 1 of 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 3, image 1 of 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 4, image 1 of 1
    • Remove the optical drive cooling fan by gripping the ribbon connector at M11 and gently remove by pulling away from the slot.
  5. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 5, image 1 of 1
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
  6. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 6, image 1 of 1
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
  7. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 7, image 1 of 1
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
  8. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 8, image 1 of 1
    • Unplug ribbon cables D4 and D5. To unplug D4, flip the gate up and pull the ribbon away.
  9. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 9, image 1 of 1
    • Remove four 1/4th inch Phillips screws on the back of the casing.
    • Unscrew and remove the nut from the threaded connector.
  10. Pioneer Elite PRO-RO6U Optical Drive Replacement: step 10, image 1 of 1
    • The optical drive is still connected by a cable on its bottom side, lift the drive upwards only slightly when first removing from the casing.
    • Pull the optical drive toward the interior of the device and then lift upwards, then pull to remove the cord on the bottom left corner before removing the drive completely.
Cody Carter
1,049 Reputation
6 Guides authored
Baylor, Team S1-G5, Johnson Spring 2018 Member of Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 299
