Pickleball Racket Grip Tape Replacement
  1. Pickleball Racket Grip Tape Replacement, Grip Tape: step 1, image 1 of 3 Pickleball Racket Grip Tape Replacement, Grip Tape: step 1, image 2 of 3 Pickleball Racket Grip Tape Replacement, Grip Tape: step 1, image 3 of 3
    • Remove the previous grip — start with the grip band and electrical tape at the top, then peel all the way down.
    Ask FixBot
  2. Pickleball Racket Grip Tape Replacement: step 2, image 1 of 2 Pickleball Racket Grip Tape Replacement: step 2, image 2 of 2
    • Clean the handle with cleansing wipes or by pulling the sticky residue off of the handle.
    Ask FixBot
  3. Pickleball Racket Grip Tape Replacement: step 3, image 1 of 3 Pickleball Racket Grip Tape Replacement: step 3, image 2 of 3 Pickleball Racket Grip Tape Replacement: step 3, image 3 of 3
    • Peel off the adhesive strip on the back of the end of the tape, then apply it flush to the bottom of the paddle handle.
    Ask FixBot
  4. Pickleball Racket Grip Tape Replacement: step 4, image 1 of 2 Pickleball Racket Grip Tape Replacement: step 4, image 2 of 2
    • Start wrapping the tape around the paddle handle upwards and diagonally.
    • Maintain tension throughout the entire process, but don’t pull too tight as to stretch the grip.
    Ask FixBot
  5. Pickleball Racket Grip Tape Replacement: step 5, image 1 of 2 Pickleball Racket Grip Tape Replacement: step 5, image 2 of 2
    • Cut from the bottom of the tape to the top at a shallow angle, then finish wrapping the tape around the shaft of the paddle.
    Ask FixBot
  6. Pickleball Racket Grip Tape Replacement: step 6, image 1 of 3 Pickleball Racket Grip Tape Replacement: step 6, image 2 of 3 Pickleball Racket Grip Tape Replacement: step 6, image 3 of 3
    • Add about a half-inch-wide strip of electrical tape to the top of the handle to hold everything in place and cover with the grip band.
    Ask FixBot
Finish Line
Evelyn Zacks
133 Reputation
1 Guide authored
UC Davis, Team 2-5, Whithaus Spring 2025 Member of UC Davis, Team 2-5, Whithaus Spring 2025
UCD-WHITHAUS-S25S2G5
2 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 220
