Introduction
If your piccolo B key pad is old, worn down, and in need of replacement, this guide will give you step by step instructions on how to replace the pad.
In the “Tools” section of this guide, a torch lighter is listed as an optional resource if there is no access to a denatured alcohol lamp. Before using the torch lighter as described in the guide, be aware the torch lighter can leave unwanted residue on the surface of the key. This could change the appearance of the key.
Many of the tools listed, including the pad, shellac glue, and key clamp, can be found on https://www.ferreestoolsinc.com/.
Use the 2.0 mm screwdriver to unscrew the top rod of the piccolo.
Once the screw is sufficiently removed, it can be completely pulled out with your fingers or with pliers.
After the screw has been removed from the rod entirely, pull the B key off of the piccolo. There should be no resistance.
