Piaggio Ciao Clutch Replacement
Video Guide
This guide was transcribed from a YouTube video.
    • Set the Piaggio Ciao on a stable stand with the engine off and cool.
    • This procedure applies to Piaggio Ciao models without a variator.
    • Gather a spark plug wrench, a piston stop, a 50 cent coin, and a 17 mm combination wrench.
    Ask FixBot
    • Use a coin about the size of a 50 cent coin to unlock the three side-cover pins by turning each pin 90 degrees.
    • Move the pedal arm downward to access the lower pin.
    • Press the lower pin inward and turn it 90 degrees.
    • Remove the side cover from the clutch side of the moped.
    Ask FixBot
    • The clutch is fixed to the crankshaft, so the clutch will spin unless the crankshaft is locked.
    • Don't lock the flywheel by wedging a screwdriver into it.
    • Use a piston stop to lock the crankshaft safely and avoid damaging the flywheel or engine.
    Ask FixBot
    • Pull the spark plug cap off the spark plug.
    • Use a spark plug wrench to unscrew the spark plug counterclockwise.
    • Thread the piston stop into the spark plug hole by hand.
    • Make sure the piston stop threads in smoothly so you don't cross-thread the cylinder head.
    • The piston stop blocks the crankshaft so the clutch nut can be loosened.
    Ask FixBot
    • Use a 17 mm combination wrench to loosen the clutch nut counterclockwise.
    • Finish unscrewing the nut by hand.
    • Remove the safety washer.
    • Keep the nut and washers in order so they return to the same positions during reassembly.
    Ask FixBot
    • Remove the washer from the crankshaft.
    • Remove the clutch shoes from the crankshaft.
    • Slide the clutch bell off the crankshaft.
    • Slide the spacer off the crankshaft last.
    • Keep the spacer with the other clutch parts so it isn't lost before reassembly.
    Ask FixBot
Install the replacement clutch and removed parts in reverse order. Remove the piston stop, reinstall the spark plug, attach the spark plug cap, and lock the side-cover pins before starting the engine. Repair didn't go as planned? Ask our Answers community for help.
Game Man
193 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 25
All Time: 25
