Philips Wake-Up HF3520/01 Disassembly
  1. Philips Wake-Up HF3520/01 Disassembly, Start: step 1, image 1 of 2 Philips Wake-Up HF3520/01 Disassembly, Start: step 1, image 2 of 2
    • There is a screw under the shiny UL sticker. Remove sticker and screw to remove this bottom panel. There are two tabs holding the panel into clock/light, so you might have to wiggle panel forward and out to remove it.
    • Next we need to gain access to more screws.
  2. Philips Wake-Up HF3520/01 Disassembly, Prying open: step 2, image 1 of 2 Philips Wake-Up HF3520/01 Disassembly, Prying open: step 2, image 2 of 2
    • Flipping the light upside down will present a small section of the bezel that can be pried upward. It is a small plastic strip with hooks that have to be disengaged to be removed. (tricky)
  3. Philips Wake-Up HF3520/01 Disassembly, Button ring: step 3, image 1 of 3 Philips Wake-Up HF3520/01 Disassembly, Button ring: step 3, image 2 of 3 Philips Wake-Up HF3520/01 Disassembly, Button ring: step 3, image 3 of 3
    • Next unscrew the two philips head screws to remove the button ring.
  4. Philips Wake-Up HF3520/01 Disassembly, Front screen shield: step 4, image 1 of 1
    • Now the screws holding the front screen shield need to be removed and the shield can be pulled away to the front.
    • Screw organization note for later: these screws have pointed ends
    • CAREFUL NOT TO DAMAGE THE INTERNAL SCREEN
    • Unscrew the four screws holding the inner screen assembly in place.
  5. Philips Wake-Up HF3520/01 Disassembly, Inner screen assembly: step 5, image 1 of 2 Philips Wake-Up HF3520/01 Disassembly, Inner screen assembly: step 5, image 2 of 2
    • The inner screen assembly can be pulled out slightly to reveal tabs on each side that hold the assembly in.
    • Pry the back tabs inwards to release.
  6. Philips Wake-Up HF3520/01 Disassembly, The guts: step 6, image 1 of 3 Philips Wake-Up HF3520/01 Disassembly, The guts: step 6, image 2 of 3 Philips Wake-Up HF3520/01 Disassembly, The guts: step 6, image 3 of 3
    • The screen is connected to the plastic domed back with holes. There are two screws at the back of the base of this domed panel. Remove screws to remove screen.
    • Set screen panel aside for safe keeping.
    • More to see and modify...
Max
1,295 Reputation
1 Guide authored
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 265
All Time: 17,346
