Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: step 1, image 1 of 3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: step 1, image 2 of 3 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: step 1, image 3 of 3
    • Pry the bottom cap away from the toothbrush body.
    • If it is not easy to open, these alternative instructions may help you.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 2, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 2, image 2 of 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 3, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 3, image 2 of 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: step 4, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: step 4, image 2 of 2
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 5, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 5, image 2 of 2
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 6, image 1 of 2 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: step 6, image 2 of 2
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
Liam Casto
354 Reputation
3 Guides authored
IUPUI, Team 1-4, Harley Spring 2024 Member of IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 52
All Time: 633
