Philips Sonicare FlexCare Battery Replacement
  1. Philips Sonicare FlexCare Battery Replacement, Battery: step 1, image 1 of 1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Battery Replacement: step 2, image 1 of 1
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
  3. Philips Sonicare FlexCare Battery Replacement: step 3, image 1 of 1
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Philips Sonicare FlexCare Battery Replacement: step 4, image 1 of 1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Battery Replacement: step 5, image 1 of 1
    • Remove the cap that is attached to the end of the interior by removing the two clasps that are holding it in place.
  6. Philips Sonicare FlexCare Battery Replacement: step 6, image 1 of 1
    • Desolder the battery from the circuit board. Here is a guide on how to desolder. Remove the old battery and replace it. Using the same guide, solder the battery in place.
    • The soldering points are shown in red.
Joanna Moraza
1,783 Reputation
2 Guides authored
Cal Poly, Team 4-6, Maness Spring 2015 Member of Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 Members
23 Guides authored
Past 24 Hours: 129
Past 7 Days: 678
Past 30 Days: 2,808
All Time: 318,601
