Philips Respironics V60 Air Inlet Filter Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Philips Respironics V60 Air Inlet Filter Replacement, shut down the ventilator: step 1, image 1 of 2 Philips Respironics V60 Air Inlet Filter Replacement, shut down the ventilator: step 1, image 2 of 2
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    • Disconnect the ventilator from the AC power.
  2. Philips Respironics V60 Air Inlet Filter Replacement, remove side panel: step 3, image 1 of 1
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
  3. Philips Respironics V60 Air Inlet Filter Replacement, replace filter: step 4, image 1 of 1
    • Remove the inlet filter by pinching it out of the recess in the bracket.
    • Install a new air filter by tucking it into the recessed area.
knipwim
8,527 Reputation
31 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 43
All Time: 1,728
