Philips Norelco BeardTrimmer 3100 Power Switch Replacement
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: step 1, image 1 of 1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 2, image 1 of 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 2, image 2 of 2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 3, image 1 of 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 3, image 2 of 2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 4, image 1 of 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 4, image 2 of 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 4, image 3 of 3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 5, image 1 of 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 5, image 2 of 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 5, image 3 of 3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 6, image 1 of 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 6, image 2 of 2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 7, image 1 of 1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 8, image 1 of 2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 8, image 2 of 2
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: step 9, image 1 of 1
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 10, image 1 of 1
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 11, image 1 of 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 11, image 2 of 3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 11, image 3 of 3
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: step 12, image 1 of 1
    • Remove the power switch from the front panel once the white plastic frame is removed.
Tamara Titus
133 Reputation
1 Guide authored
USF Tampa, Team 15-2, Blackwell Fall 2015 Member of USF Tampa, Team 15-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G2
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 37
All Time: 5,836
