Shop the Holiday Gift Guide
Philips HD9252 Transformer Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
31
Past 30 Days:
126
All Time:
2,015
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Follow this guide for instructions on how to remove and replace the air fryer's transformer. Removal of the transformer may be required if the device is being taken to another country where power outlets are different from the United States.
Tools
    1. Philips HD9252 Transformer Replacement, Top: step 1, image 1 of 1
      • Insert a nylon spudger underneath the top of the device.
      • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
      Ask FixBot
    2. Philips HD9252 Transformer Replacement: step 2, image 1 of 1
      • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
      Ask FixBot
    3. Philips HD9252 Transformer Replacement: step 3, image 1 of 1
      • Remove the top by lifting it upwards and setting it down.
      Ask FixBot
    1. Philips HD9252 Transformer Replacement, Transformer: step 4, image 1 of 1
      • Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
      Ask FixBot
    2. Philips HD9252 Transformer Replacement: step 5, image 1 of 1
      • Remove the top piece, using a Phillips #2 screwdriver, to get the whole transformer.
      Ask FixBot
    3. Philips HD9252 Transformer Replacement: step 6, image 1 of 2 Philips HD9252 Transformer Replacement: step 6, image 2 of 2
      • Remove the brown and white wire attached to the transformer using a spudger.
      • Disconnect both the brown and white cables.
      Ask FixBot
    4. Philips HD9252 Transformer Replacement: step 7, image 1 of 1
      • Replace the transformer.
      Ask FixBot
Author
with
Zach Person
685 Reputation
4 Guides authored
1 Guide Comment
This is not the transformer, it is the coil of the shaded-pole motor.
Werner Hinzmann - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 126
All Time: 2,015
