Philips DC320 37 Speaker Replacement
  1. Philips DC320 37 Speaker Replacement, Docking entertainment system: step 1, image 1 of 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Speaker Replacement: step 2, image 1 of 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Speaker Replacement: step 3, image 1 of 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Speaker Replacement: step 4, image 1 of 3 Philips DC320 37 Speaker Replacement: step 4, image 2 of 3 Philips DC320 37 Speaker Replacement: step 4, image 3 of 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Speaker Replacement, Speaker: step 5, image 1 of 1
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
  6. Philips DC320 37 Speaker Replacement: step 6, image 1 of 3 Philips DC320 37 Speaker Replacement: step 6, image 2 of 3 Philips DC320 37 Speaker Replacement: step 6, image 3 of 3
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
  7. Philips DC320 37 Speaker Replacement: step 7, image 1 of 1
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
  8. Philips DC320 37 Speaker Replacement: step 8, image 1 of 2 Philips DC320 37 Speaker Replacement: step 8, image 2 of 2
    • Slide the speaker towards the bottom of the device to remove.
Graham Rolph
1 Reputation
2 Guides authored
Cal Poly, Team 3-48, Amido Spring 2013 Member of Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 913
