Up to 20% off select tools
Perfect Cooker RC301M Disassembly
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
79
All Time:
1,089
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This is the Perfect Cooker RC301M. In this guide, we will be disassembling this rice cooker to gain a better idea of how this device works and for optimal cleaning.
Featured Document
Preview of the first page of this document
Kitchen
Log in to view the full document
Log In
    1. Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: step 1, image 1 of 2 Perfect Cooker RC301M Disassembly, Perfect Cooker RC301M Disassembly: step 1, image 2 of 2
      • Remove the power cord and find a clean flat surface to work at.
      Ask FixBot
    2. Perfect Cooker RC301M Disassembly: step 2, image 1 of 3 Perfect Cooker RC301M Disassembly: step 2, image 2 of 3 Perfect Cooker RC301M Disassembly: step 2, image 3 of 3
      • Remove the lid by unhinging the side tabs.
      • Remove the inner pot and any other contents.
      Ask FixBot
    3. Perfect Cooker RC301M Disassembly: step 3, image 1 of 3 Perfect Cooker RC301M Disassembly: step 3, image 2 of 3 Perfect Cooker RC301M Disassembly: step 3, image 3 of 3
      • Flip the device over and look for the two screws recessed underneath the device.
      Ask FixBot
    4. Perfect Cooker RC301M Disassembly: step 4, image 1 of 3 Perfect Cooker RC301M Disassembly: step 4, image 2 of 3 Perfect Cooker RC301M Disassembly: step 4, image 3 of 3
      • Using a Phillips #2 screwdriver, remove the two 32.8 mm screws.
      Ask FixBot
    5. Perfect Cooker RC301M Disassembly: step 5, image 1 of 1
      • Carefully lift up the bottom to reveal the wires and mechanism.
      • Make sure not to pull it up too much as it is still connected to the device body with the center metal mechanism.
      Ask FixBot
    6. Perfect Cooker RC301M Disassembly: step 6, image 1 of 1
      • The center mechanism is directly in the center of the device and connects the switch to the middle
      • This part of the device raises and lowers the burner to change from the cook to warm function.
      • The two parts of the mechanism are connected by a simple metal “T-shaped” tab.
      Ask FixBot
    7. Perfect Cooker RC301M Disassembly: step 7, image 1 of 3 Perfect Cooker RC301M Disassembly: step 7, image 2 of 3 Perfect Cooker RC301M Disassembly: step 7, image 3 of 3
      • Disconnect the two metal arms.
      • It can be seen that the metal tab must be bent into a “U-shape” in order to fit through the other arm of the mechanism.
      • Take the small chain nose pliers and bend each side of the “T-shaped” tab inwards.
      • Use trial and error to bend the tabs until they are able to fit through the “U-shape” cut out in the other arm.
      Ask FixBot
    8. Perfect Cooker RC301M Disassembly: step 8, image 1 of 2 Perfect Cooker RC301M Disassembly: step 8, image 2 of 2
      • Separate the two parts of the devices.
      • The "U-shape" cut out can now be clearly seen.
      • The T-tab remains in the "U-shape" after slipping through the slot.
      Ask FixBot
Attached Documents
Author
with
Emma Gonzalez
207 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 79
All Time: 1,089
