Pentax ZX-5n Shutter Unit Replacement
    1. Pentax ZX-5n Shutter Unit Replacement, Remove back cover: step 1, image 1 of 1
      • Push down on the screw to depress the spring loaded hinge and release the door.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, Remove bottom cover: step 2, image 1 of 1
      • Remove six 5.3 mm #00 screws.
      • Remove one 3.4 mm #00 screw.
      • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
      Ask FixBot
    3. Pentax ZX-5n Shutter Unit Replacement, Remove left front cover: step 3, image 1 of 1
      • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
      • Remove one 7.3 mm #00 screw.
      • Remove the remote trigger cover.
      Ask FixBot
    4. Pentax ZX-5n Shutter Unit Replacement, Remove front cover: step 4, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Remove front cover: step 4, image 2 of 2
      • Remove two 5.3 mm #00 screw.
      • Gently lift up on the flash housing to help remove the cover if necessary.
      Ask FixBot
    5. Pentax ZX-5n Shutter Unit Replacement, Remove right front cover: step 5, image 1 of 1
      • Remove two 3.9 mm #00 screws.
      Ask FixBot
    1. Pentax ZX-5n Shutter Unit Replacement, Remove eye cup: step 6, image 1 of 1
      • Slide the eye cup up and off to access the screws underneath.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, Unscrew top cover: step 7, image 1 of 3 Pentax ZX-5n Shutter Unit Replacement, Unscrew top cover: step 7, image 2 of 3 Pentax ZX-5n Shutter Unit Replacement, Unscrew top cover: step 7, image 3 of 3
      • Remove two 5.3 mm #00 screws by the eyepiece.
      • Remove one 6.8 mm #00 screw in the battery compartment.
      • Remove one 7.0 mm #00 screw near the take up spool.
      Ask FixBot
    3. Pentax ZX-5n Shutter Unit Replacement, Lift top cover: step 8, image 1 of 1
      • Lift the cover so it is just free of the body. It is still attached by several wires.
      Ask FixBot
    4. Pentax ZX-5n Shutter Unit Replacement, Discharge flash capacitors: step 9, image 1 of 1
      • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      Ask FixBot
    5. Pentax ZX-5n Shutter Unit Replacement, Unsolder flash connections: step 10, image 1 of 1
      • Unsolder one green wire.
      • Unsolder one blue wire.
      • Unsolder one brown wire.
      • Unsolder one black wire.
      Ask FixBot
    6. Pentax ZX-5n Shutter Unit Replacement, Unsolder remaining connections: step 11, image 1 of 3 Pentax ZX-5n Shutter Unit Replacement, Unsolder remaining connections: step 11, image 2 of 3 Pentax ZX-5n Shutter Unit Replacement, Unsolder remaining connections: step 11, image 3 of 3
      • Pull black wire out from its routed location.
      • Unsolder flex connector
      • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
      • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
      Ask FixBot
    1. Pentax ZX-5n Shutter Unit Replacement, De-solder battery connections: step 12, image 1 of 1
      • De-solder the indicated joints. Use a solder sucker on the tabbed connections.
      • Pull the black wire from the battery flex to get more slack in the connection to the top cover.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, De-solder flex posts: step 13, image 1 of 1
      • Use a solder sucker to de-solder the four posts from the flex circuit.
      • This is the most difficult part of the repair. Patience and persistence are required.
      Ask FixBot
    3. Pentax ZX-5n Shutter Unit Replacement, De-solder flex connections: step 14, image 1 of 1
      • Unsolder film advance motor connections.
      • Unsolder sprocket counter connections.
      • Unsolder power and ground connections.
      • Unsolder panorama switch connections.
      Ask FixBot
    4. Pentax ZX-5n Shutter Unit Replacement, Unscrew flex circuit: step 15, image 1 of 1
      • Remove one 4.3 mm #00 screw.
      Ask FixBot
    5. Pentax ZX-5n Shutter Unit Replacement, Lift the flex circuit: step 16, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Lift the flex circuit: step 16, image 2 of 2
      • Gently pry up the plastic carrier under the flex circuit. It may catch slightly on the battery contact tab.
      • Pay close attention to the connections around the four through-hole posts as you lift the flex. Make sure that no solder is left over and that it pulls away freely.
      • This metal tab is lightly held in place with lacquer and can easily come loose. Keep an eye on it.
      Ask FixBot
    1. Pentax ZX-5n Shutter Unit Replacement, Unscrew flash PCB: step 17, image 1 of 1
      • Remove one 3.3mm #00 screw.
      • Remove one 3.9 #00 screw.
      • De-solder the red wire.
      • Peel off the black tape. Leave it attached to the wires.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, Remove flash PCB and capacitors: step 18, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Remove flash PCB and capacitors: step 18, image 2 of 2
      • Gently peel the flex circuit from the surface of the capacitor.
      • There may be additional adhesive underneath the larger capacitor.
      • Lift the two capacitors and the flash PCB out as a single unit.
      • The double sided tape used to secure the capacitors can be softened with isopropyl alcohol if necessary.
      Ask FixBot
    1. Pentax ZX-5n Shutter Unit Replacement, Prepare bottom plate: step 19, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Prepare bottom plate: step 19, image 2 of 2
      • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
      • Peel tape from the plate. Leave the tape attached to the flex circuit.
      • Remove the flex circuits from their retaining studs.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, Remove bottom plate: step 20, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Remove bottom plate: step 20, image 2 of 2
      • Remove one 3.3 mm #0 countersunk screw.
      • Remove one 3.9 mm #0 shoulder screw.
      • Remove four 3.3 mm #00 screws.
      • Pull a little slack through the housing on this flex cable.
      • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
      • To the camera tech that left me a happy little note...I see you.
      Ask FixBot
    3. Pentax ZX-5n Shutter Unit Replacement, Remove transport gears: step 21, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Remove transport gears: step 21, image 2 of 2
      • It's best to remove these parts now so they don't fall out later on in the repair.
      Ask FixBot
    1. Pentax ZX-5n Shutter Unit Replacement, Detach DOF preview switch: step 22, image 1 of 1
      • Remove one 3.8 mm #00 screw.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, De-solder shutter control flex: step 23, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, De-solder shutter control flex: step 23, image 2 of 2
      • De-solder the connections.
      • Lift the flex off the retaining studs.
      Ask FixBot
    3. Pentax ZX-5n Shutter Unit Replacement, Remove eye piece assembly: step 24, image 1 of 1
      • Remove two 5.3 mm #0 screws.
      Ask FixBot
    4. Pentax ZX-5n Shutter Unit Replacement, Unscrew front housing block: step 25, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Unscrew front housing block: step 25, image 2 of 2
      • Remove two 7.4 mm #0 screws.
      • Remove one 8.3 mm #0 screw.
      • Remove one 3.3 mm #00 screw. The metal bracket will be loose and should be removed as well.
      Ask FixBot
    5. Pentax ZX-5n Shutter Unit Replacement, Lift front housing block: step 26, image 1 of 1
      • Push the front housing block slightly up then lift the left side up and away from the housing.
      • Proceed slowly and watch for any components that are catching. The right side is still attached by a large flex cable.
      Ask FixBot
    6. Pentax ZX-5n Shutter Unit Replacement, Check for shims: step 27, image 1 of 1
      • There may be shims at the mounting points of the front housing block.
      • Note the positions and remove if loose.
      Ask FixBot
    1. Pentax ZX-5n Shutter Unit Replacement, Remove panorama switch: step 28, image 1 of 3 Pentax ZX-5n Shutter Unit Replacement, Remove panorama switch: step 28, image 2 of 3 Pentax ZX-5n Shutter Unit Replacement, Remove panorama switch: step 28, image 3 of 3
      • Remove one X mm #00 screw.
      • Remove panorama switch contact.
      • Pull panorama switch apart and remove both pieces.
      Ask FixBot
    2. Pentax ZX-5n Shutter Unit Replacement, Remove shutter unit: step 29, image 1 of 2 Pentax ZX-5n Shutter Unit Replacement, Remove shutter unit: step 29, image 2 of 2
      • Remove two X mm #00 screw.
      • Remove shutter unit.
      Ask FixBot
Sam Gustafson
14,634 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 28
All Time: 401
