Pentax Super Program Mirror Box Removal
  1. Pentax Super Program Mirror Box Removal, Remove film advance lever: step 1, image 1 of 3 Pentax Super Program Mirror Box Removal, Remove film advance lever: step 1, image 2 of 3 Pentax Super Program Mirror Box Removal, Remove film advance lever: step 1, image 3 of 3
    • Remove the rubber decorative cap. It is attached with contact cement underneath. Isopropyl Alcohol may be used to soften the adhesive.
    • Unscrew the lock nut using a spanner wrench. The lock nut is reverse threaded.
    • Lift off the advance lever.
    • Remove the spring washer.
    • Remove one shim washer.
  2. Pentax Super Program Mirror Box Removal, Remove mode dial: step 2, image 1 of 2 Pentax Super Program Mirror Box Removal, Remove mode dial: step 2, image 2 of 2
    • Set the mode dial to the 'L' position.
    • Use a spanner wrench to unscrew the dial lock nut.
    • Lift off the mode dial.
  3. Pentax Super Program Mirror Box Removal, Remove exposure compensation dial: step 3, image 1 of 3 Pentax Super Program Mirror Box Removal, Remove exposure compensation dial: step 3, image 2 of 3 Pentax Super Program Mirror Box Removal, Remove exposure compensation dial: step 3, image 3 of 3
    • Place a rigid object in the fork.
    • Unscrew the rewind lever.
    • Use a spanner wrench to remove the lock nut.
    • Lift off the exposure compensation dial.
  4. Pentax Super Program Mirror Box Removal, Remove top cover screws: step 4, image 1 of 3 Pentax Super Program Mirror Box Removal, Remove top cover screws: step 4, image 2 of 3 Pentax Super Program Mirror Box Removal, Remove top cover screws: step 4, image 3 of 3
    • Remove two screws on either side of the eye piece.
    • Remove two screws on either side of the lens mount.
  5. Pentax Super Program Mirror Box Removal, Remove top cover: step 5, image 1 of 3 Pentax Super Program Mirror Box Removal, Remove top cover: step 5, image 2 of 3 Pentax Super Program Mirror Box Removal, Remove top cover: step 5, image 3 of 3
    • Remove one screw by the exposure compensation dial.
    • Use a spanner wrench to remove the lock nut under the advance lever.
    • Lift off the top cover slowly. It is still attached by one wire.
    • Unsolder one gray flash sync wire.
  6. Pentax Super Program Mirror Box Removal, Remove bottom cover: step 6, image 1 of 1
    • Remove three M1.7 x 3 mm screws.
    • Remove bottom cover.
  7. Pentax Super Program Mirror Box Removal, Remove front leatherette panels: step 7, image 1 of 3 Pentax Super Program Mirror Box Removal, Remove front leatherette panels: step 7, image 2 of 3 Pentax Super Program Mirror Box Removal, Remove front leatherette panels: step 7, image 3 of 3
    • Use a nickel or other large coin to remove the hand grip.
    • Drip isopropyl alcohol along the edge of the leatherette to soften the adhesive.
    • Use a dull scraper to lift one corner and pull off the panel.
    • Repeat on the rewind side of the camera.
    • Installation Notes: Use contact cement to reattach the leatherette after the camera has been fully reassembled and tested.
  8. Pentax Super Program Mirror Box Removal, Detach flex PCB with adjustment pots: step 8, image 1 of 2 Pentax Super Program Mirror Box Removal, Detach flex PCB with adjustment pots: step 8, image 2 of 2
    • Remove one M1.7 x 4.5 mm screw.
    • Remove one slotted screw.
    • Use isopropyl alcohol to soften the adhesive under the flex PCB.
    • Gently lift the PCB until it is free from the camera body.
  9. Pentax Super Program Mirror Box Removal, Unsolder wires under bottom plate: step 9, image 1 of 1
    • Unsolder one red wire.
    • Unsolder one light blue wire.
    • Unsolder one orange wire.
    • Unsolder one purple wire.
  10. Pentax Super Program Mirror Box Removal, Remove tripod mount: step 10, image 1 of 2 Pentax Super Program Mirror Box Removal, Remove tripod mount: step 10, image 2 of 2
    • Remove one M1.7 x 5 mm screw.
    • Remove one countersunk M1.7 x 5.5 mm screw.
    • Lift the contact terminal free from its seat.
    • Remove the tripod mount.
  11. Pentax Super Program Mirror Box Removal, Detach ISO resistor assembly: step 11, image 1 of 2 Pentax Super Program Mirror Box Removal, Detach ISO resistor assembly: step 11, image 2 of 2
    • Remove one M1.7 x 4 mm screw.
    • Loosen one slotted screw (this will remain connected to the assembly).
    • Lift the ISO resistor assembly off the rewind post. It is still attached by a flex PCB.
  12. Pentax Super Program Mirror Box Removal, Detach mode dial unit: step 12, image 1 of 3 Pentax Super Program Mirror Box Removal, Detach mode dial unit: step 12, image 2 of 3 Pentax Super Program Mirror Box Removal, Detach mode dial unit: step 12, image 3 of 3
    • Remove one M1.7 x 2.5 mm screw. It is only accessible when the mode dial is in the 'L' position.
    • Remove one crosshead screw.
    • Lift the LCD out of the way. It is still attached by a flex PCB.
  13. Pentax Super Program Mirror Box Removal, Unsolder flash sync and shutter wires: step 13, image 1 of 2 Pentax Super Program Mirror Box Removal, Unsolder flash sync and shutter wires: step 13, image 2 of 2
    • Unsolder one gray wire.
    • Unsolder one brown wire.
    • Unsolder one white wire.
  14. Pentax Super Program Mirror Box Removal, Unscrew front board: step 14, image 1 of 2 Pentax Super Program Mirror Box Removal, Unscrew front board: step 14, image 2 of 2
    • Remove four M1.9 x 5 mm screws.
  15. Pentax Super Program Mirror Box Removal, Unscrew mirror box: step 15, image 1 of 2 Pentax Super Program Mirror Box Removal, Unscrew mirror box: step 15, image 2 of 2
    • Remove two M1.7 x 2.5 mm screws.
    • Remove one M1.7 x 3.5 mm screw under the bottom plate.
    • Some versions of the camera may have an additional screw under the tripod mount that needs to be removed.
  16. Pentax Super Program Mirror Box Removal, Remove mirror box and front board: step 16, image 1 of 2 Pentax Super Program Mirror Box Removal, Remove mirror box and front board: step 16, image 2 of 2
    • Wind the shutter
    • Make sure the mode dial unit and ISO selector unit are free from their mounting points.
    • Wiggle the mirror box and front board free.
    • Watch for wire snags as you pull it free.
    • Check for loose shim washers on the front board and note their position.
  17. Pentax Super Program Mirror Box Removal, Installation Notes: Front Block: step 17, image 1 of 1
    • Shutter should be in the charged state.
    • Mirror box should be in released state.
    • Pay close attention to wire routing during install.
    • To test the actuation of the mirror and shutter, wind the camera, then insert a tool into this slot and push the release lever to the left.
Sam Gustafson
10,623 Reputation
57 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 193
