Pentax MX Self-Timer Lever Disassembly
    1. Pentax MX Self-Timer Lever Disassembly, Remove film advance lever: step 1, image 1 of 3 Pentax MX Self-Timer Lever Disassembly, Remove film advance lever: step 1, image 2 of 3 Pentax MX Self-Timer Lever Disassembly, Remove film advance lever: step 1, image 3 of 3
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      Ask FixBot
    2. Pentax MX Self-Timer Lever Disassembly, Remove shutter speed dial: step 2, image 1 of 2 Pentax MX Self-Timer Lever Disassembly, Remove shutter speed dial: step 2, image 2 of 2
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      Ask FixBot
    3. Pentax MX Self-Timer Lever Disassembly, Remove rewind knob: step 3, image 1 of 3 Pentax MX Self-Timer Lever Disassembly, Remove rewind knob: step 3, image 2 of 3 Pentax MX Self-Timer Lever Disassembly, Remove rewind knob: step 3, image 3 of 3
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      Ask FixBot
    4. Pentax MX Self-Timer Lever Disassembly, Remove top cover: step 4, image 1 of 3 Pentax MX Self-Timer Lever Disassembly, Remove top cover: step 4, image 2 of 3 Pentax MX Self-Timer Lever Disassembly, Remove top cover: step 4, image 3 of 3
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      Ask FixBot
    1. Pentax MX Self-Timer Lever Disassembly, Remove front leatherette panels: step 5, image 1 of 3 Pentax MX Self-Timer Lever Disassembly, Remove front leatherette panels: step 5, image 2 of 3 Pentax MX Self-Timer Lever Disassembly, Remove front leatherette panels: step 5, image 3 of 3
      • Apply isopropyl alcohol to soften the leatherette adhesive.
      • Turn the self-timer lever to the charged position.
      • Peel the leatherette off the camera body, carefully working it over the self-timer lever.
      • Remove one loose cover panel.
      • Repeat for the opposite panel.
      • Installation Notes: Clean all the old adhesive off of the camera body and leatherette panels before reapplying. Use contact cement to attach.
      Ask FixBot
    2. Pentax MX Self-Timer Lever Disassembly, Unsolder aperture resistor: step 6, image 1 of 1
      • Unsolder two yellow wires for the aperture resistor.
      Ask FixBot
    3. Pentax MX Self-Timer Lever Disassembly, Remove front board: step 7, image 1 of 3 Pentax MX Self-Timer Lever Disassembly, Remove front board: step 7, image 2 of 3 Pentax MX Self-Timer Lever Disassembly, Remove front board: step 7, image 3 of 3
      • Remove four M1.9 x 3.9 mm screws.
      • Lift off front board.
      • Look for shim washers at the screw locations and note their positions.
      Ask FixBot
    1. Pentax MX Self-Timer Lever Disassembly, Remove decorative cap: step 8, image 1 of 3 Pentax MX Self-Timer Lever Disassembly, Remove decorative cap: step 8, image 2 of 3 Pentax MX Self-Timer Lever Disassembly, Remove decorative cap: step 8, image 3 of 3
      • The cap is secured with glue and can be difficult to remove. Work with patience.
      • Flood the cap with isopropyl alcohol. Some will seep underneath and soften the adhesive.
      • Work the cap loose with a soft tool, either wood or plastic. Metal tools will leave marks.
      • If the cap will not come loose, use contact adhesive to attach a tool to the face of the cap. The extra leverage will help to remove it. The contact adhesive can be removed later.
      Ask FixBot
    2. Pentax MX Self-Timer Lever Disassembly, Remove self-timer lever: step 9, image 1 of 2 Pentax MX Self-Timer Lever Disassembly, Remove self-timer lever: step 9, image 2 of 2
      • Remove one M1.7 x 3.8 mm screw.
      • Lift off the self-timer lever.
      • Remove the lever shaft from the backside.
      • Installation Notes: A thin coat of medium weight moly grease on the lever shaft can improve the feel of the lever and prevent wear.
      Ask FixBot
    3. Pentax MX Self-Timer Lever Disassembly, Remove the aperture preview linkage: step 10, image 1 of 2 Pentax MX Self-Timer Lever Disassembly, Remove the aperture preview linkage: step 10, image 2 of 2
      • Remove the bias spring.
      • Remove three M1.4 x 2.8 mm countersunk screws.
      • Remove the aperture preview linkage.
      Ask FixBot
    4. Pentax MX Self-Timer Lever Disassembly, Remove the mounting plate: step 11, image 1 of 1
      • Remove the self-timer lever mounting plate.
      • Clean all parts as necessary.
      Ask FixBot
Sam Gustafson
14,634 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 68
All Time: 224
