Introduction
This guide details the steps to perform a standard service for the high speed components of the shutter. It shows how to access the lubrication points for the shutter curtains and how to disassemble and clean some of the important components. Very dirty or poorly performing shutters may require more disassembly in order to properly clean them.
The guide may also be helpful for troubleshooting malfunctions that occur when the camera is fired.
Remove the lever cap. The cap is reverse threaded.
Lift off the advance lever.
Remove the collar beneath the lever.
Set the ISO to 100 and the shutter speed to 1000.
Remove one pin head screw.
Lift off shutter speed dial.
Remove the collar beneath the dial.
Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
Remove the lock ring underneath the rewind knob.
Remove the cover plate.
Remove two M1.7 x 3.2 mm screws.
Remove two M1.7 x 2 mm countersunk screws.
Lift off top cover.
The release cable pin in the shutter button is loose and may fall out.
Apply isopropyl alcohol to soften the leatherette adhesive.
Turn the self-timer lever to the charged position.
Peel the leatherette off the camera body, carefully working it over the self-timer lever.
Remove one loose cover panel.
Repeat for the opposite panel.
Remove four M1.9 x 3.9 mm screws.
Lift off front board.
Look for shim washers at the screw locations and note their positions.
Remove three M1.7 x 2.0 mm countersunk screws.
Lift off bottom cover.
Remove loose plastic housing for motor drive contacts.
Remove four M1.9 x 3.8 mm screws.
Lift off light baffle.
Use isopropyl alcohol to soften adhesive and detach wires from the backside of the baffle.
Unsolder two brown wires for the shutter speed resistor.
Unsolder one gray for the x-sync.
Unsolder one white wire for the FP sync.
Unsolder one green wire for the motor drive connection.
Unsolder one blue wire for the LED switch.
Unsolder one red wire and one black wire.
Open up wire routing guides and remove all wires from them.
Pull the black and red wires out of the hole in the bottom of the chassis.
Make sure the gray wire is free and can pull away with the mirror box.
Remove one M1.4 x 2.8 mm screw and washer.
Remove one M1.7 x 2.8 mm screw.
Pull the LED PCB out of the side of the mirror box.
Loosen the slotted post but do not remove.
Slide the idler gear back so that it no longer engages with the speed indicator disc.
Remove two M1.7 x 4.6 mm screws.
Remove two slotted posts.
Lift the mirror box up and tilt the top forward to remove it.
Temporarily install the wind lever and the shutter speed dial.
Wind the camera.
Press the shutter release button.
Release the opening curtain latch. This is usually done by the mirror box but has to be done manually in this case.
Temporarily replace the wind lever and move it into the stowed position.
Remove one M1.7 x 2.4 mm countersunk screw.
Remove one M1.7 x 3.8 mm screw.
Remove one M1.4 slotted nut.
Lift off frame counter mechanism.
Align the post on the ratcheting gear with the slot in the top wind gear.
The frame counter gears will also need to mesh when installed.
Check the placement of this spring. It often comes loose.
Remove two screws.
Lift off support plate. It is still connected to the shutter speed dial by a thin cable.
Remove two shim washers.
Remove the door latch spring arm.
Installation Notes: Route the cable through the pulleys as shown before installing the support plate.
Remove three screws.
Remove speed selector plate
Lift off high speed cam.
Remove spacer washer.
Clean the high speed cam and the seat that it operates in. Apply shutter oil to the shaft and hole.
Set the speed selector to the '1000' position.
The cam for the slow speed governor should be in this position to sync properly with the speed selector.
Ensure that the shaft to the slow speed governor couples properly.
Mark the vertical position of the shutter release arm on the release shaft.
Remove two M1.4 x 2.4 mm screws.
Remove shutter release arm.
Remove one M1.4 x 2.4 mm screw.
Remove the shutter release plate.
Slide the shutter release shaft out from the bottom of the camera.
Keep track of the coil spring as it slides off.
Push the latch out from between the wind gears and slide it off the shaft.
Installation Notes: Note the position of the bias springs during installation.
Remove one slotted post.
Remove plate.
Remove upper transport gear latch.
Remove upper transport gear.
Shutter curtains should be in the wound state...
And the lower transport gear latch engaged.
Place the upper transport gear such that the right side of the slot is as close to the transport latch as possible without touching or rubbing.
Unhook bias spring.
Remove one M1.4 x 2.8 mm shoulder screw.
Remove lower transport gear latch and bias spring.
Remove washer.
Lubricate the pinion shafts. On the wind side, the pinions turn in their end pivots. The oil should be between the shafts and the end plates.
Lubricate the rollers. On the rewind side, the rollers turn on the fixed shafts. The oil should be between the rollers and the shafts.
