Pentax MX Frame Counter Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
30
Past 30 Days:
113
All Time:
432
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Pentax MX Frame Counter Disassembly, Remove film advance lever: step 1, image 1 of 3 Pentax MX Frame Counter Disassembly, Remove film advance lever: step 1, image 2 of 3 Pentax MX Frame Counter Disassembly, Remove film advance lever: step 1, image 3 of 3
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      Ask FixBot
    2. Pentax MX Frame Counter Disassembly, Remove shutter speed dial: step 2, image 1 of 2 Pentax MX Frame Counter Disassembly, Remove shutter speed dial: step 2, image 2 of 2
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      Ask FixBot
    3. Pentax MX Frame Counter Disassembly, Remove rewind knob: step 3, image 1 of 3 Pentax MX Frame Counter Disassembly, Remove rewind knob: step 3, image 2 of 3 Pentax MX Frame Counter Disassembly, Remove rewind knob: step 3, image 3 of 3
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      Ask FixBot
    4. Pentax MX Frame Counter Disassembly, Remove top cover: step 4, image 1 of 3 Pentax MX Frame Counter Disassembly, Remove top cover: step 4, image 2 of 3 Pentax MX Frame Counter Disassembly, Remove top cover: step 4, image 3 of 3
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      Ask FixBot
    1. Pentax MX Frame Counter Disassembly, Remove frame counter assembly: step 5, image 1 of 3 Pentax MX Frame Counter Disassembly, Remove frame counter assembly: step 5, image 2 of 3 Pentax MX Frame Counter Disassembly, Remove frame counter assembly: step 5, image 3 of 3
      • Temporarily replace the wind lever and move it into the stowed position.
      • Remove one M1.7 x 2.4 mm countersunk screw.
      • Remove one M1.7 x 3.8 mm screw.
      • Remove one M1.4 slotted nut.
      • Lift off frame counter mechanism.
      Ask FixBot
    2. Pentax MX Frame Counter Disassembly, Installation Notes: Frame Count Assembly: step 6, image 1 of 2 Pentax MX Frame Counter Disassembly, Installation Notes: Frame Count Assembly: step 6, image 2 of 2
      • Align the post on the ratcheting gear with the slot in the top wind gear.
      • The frame counter gears will also need to mesh when installed.
      • Check the placement of this spring. It often comes loose.
      Ask FixBot
Sam Gustafson
14,868 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 113
All Time: 432
