Pelonis Four Slice Toaster Oven Disassembly
  1. Pelonis Four Slice Toaster Oven Disassembly, Pelonis Four Slice Toaster Oven: step 1, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly, Pelonis Four Slice Toaster Oven: step 1, image 2 of 2
    • Remove the two 12 mm screws at the bottom of the toaster using a Phillips #1 screwdriver.
    Ask FixBot
  2. Pelonis Four Slice Toaster Oven Disassembly: step 2, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 2, image 2 of 2
    • Remove the four 8 mm screws from the inside edge of the toaster using a Phillips #0 screwdriver.
    Ask FixBot
  3. Pelonis Four Slice Toaster Oven Disassembly: step 3, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 3, image 2 of 2
    • Remove the four 12 mm screws at the back of the toaster using a Phillips #1 screwdriver.
    Ask FixBot
  4. Pelonis Four Slice Toaster Oven Disassembly: step 4, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 4, image 2 of 2
    • Remove the rubber backings from the legs of the toaster by pulling them out with your hands.
    Ask FixBot
  5. Pelonis Four Slice Toaster Oven Disassembly: step 5, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 5, image 2 of 2
    • Remove the 12 mm screw from the inside of the leg using a Phillips #0 screwdriver.
    • This allows us to remove the leg stands from the toaster.
    Ask FixBot
  6. Pelonis Four Slice Toaster Oven Disassembly: step 6, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 6, image 2 of 2
    • Remove the back to access the inner mechanism; you can also remove the black covering at this step.
    Ask FixBot
  7. Pelonis Four Slice Toaster Oven Disassembly: step 7, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 7, image 2 of 2
    • The LED light can be removed for replacement.
    Ask FixBot
  8. Pelonis Four Slice Toaster Oven Disassembly: step 8, image 1 of 3 Pelonis Four Slice Toaster Oven Disassembly: step 8, image 2 of 3 Pelonis Four Slice Toaster Oven Disassembly: step 8, image 3 of 3
    • Remove the 12 mm screws surrounding the temperature switch using a Phillips #1 screwdriver.
    Ask FixBot
  9. Pelonis Four Slice Toaster Oven Disassembly: step 9, image 1 of 2 Pelonis Four Slice Toaster Oven Disassembly: step 9, image 2 of 2
    • The temperature switch is now free for replacement.
    Ask FixBot
  10. Pelonis Four Slice Toaster Oven Disassembly: step 10, image 1 of 3 Pelonis Four Slice Toaster Oven Disassembly: step 10, image 2 of 3 Pelonis Four Slice Toaster Oven Disassembly: step 10, image 3 of 3
    • With all other components out of the way, you have access to the wires connecting to the heating elements as well as the heating elements themselves, which you can now replace.
    Ask FixBot
Attached Documents
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 129
