Introduction
Replacement guide for the screen cover of the Pebble Time.
Use the metal spudger to carefully pull apart the screen cover from the case.
Replace the metal spudger with a plastic opening tool to hold the cover open.
Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
5 Comments
What does one use to hold the screen on and reseal for waterproofing?
Using RTV silicon is problematic, I got some on my LCD and now Iām looking for a replacement Pebble.
HI I scratched my Crystal on my Pebble Time watch. Can the Crystal be buffed to get the scratch out??
This is a brand new Pebble Time watch!!
āCONCLUSION
To reassemble your device, follow these instructions in reverse order.ā
Yeah, what about an adhesive or sealant? Best practice for doing so?
