Parrot Skycontroller 2 USB Port Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
58
All Time:
1,332
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
In this guide, the USB port will be replaced on the Parrot Skycontroller 2P. If you are having trouble, with your phone connecting to the device, the USB port could be the problem. This guide will require desoldering and soldering the port, so check out our How to Solder and Desolder Connections guide for help on how to do so.
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Tools
    1. Parrot Skycontroller 2 USB Port Replacement, Battery: step 1, image 1 of 3 Parrot Skycontroller 2 USB Port Replacement, Battery: step 1, image 2 of 3 Parrot Skycontroller 2 USB Port Replacement, Battery: step 1, image 3 of 3
      • Flip your controller face down.
      Ask FixBot
    2. Parrot Skycontroller 2 USB Port Replacement: step 2, image 1 of 1
      • Remove one 9mm screw using a #4 flathead screwdriver.
      Ask FixBot
    3. Parrot Skycontroller 2 USB Port Replacement: step 3, image 1 of 3 Parrot Skycontroller 2 USB Port Replacement: step 3, image 2 of 3 Parrot Skycontroller 2 USB Port Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
      • Remove the cover by pulling up and out.
      Ask FixBot
    4. Parrot Skycontroller 2 USB Port Replacement: step 4, image 1 of 3 Parrot Skycontroller 2 USB Port Replacement: step 4, image 2 of 3 Parrot Skycontroller 2 USB Port Replacement: step 4, image 3 of 3
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
      Ask FixBot
    5. Parrot Skycontroller 2 USB Port Replacement: step 5, image 1 of 2 Parrot Skycontroller 2 USB Port Replacement: step 5, image 2 of 2
      • Remove the battery from its brackets by pulling up on the ends of the battery.
      Ask FixBot
    1. Parrot Skycontroller 2 USB Port Replacement, USB Port: step 6, image 1 of 1
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • Pull back the sticker with your finger nail and remove one 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      Ask FixBot
    2. Parrot Skycontroller 2 USB Port Replacement: step 7, image 1 of 3 Parrot Skycontroller 2 USB Port Replacement: step 7, image 2 of 3 Parrot Skycontroller 2 USB Port Replacement: step 7, image 3 of 3
      • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      Ask FixBot
    3. Parrot Skycontroller 2 USB Port Replacement: step 8, image 1 of 1
      • Remove the battery compartment plate by pulling up and out.
      Ask FixBot
    4. Parrot Skycontroller 2 USB Port Replacement: step 9, image 1 of 2 Parrot Skycontroller 2 USB Port Replacement: step 9, image 2 of 2
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      Ask FixBot
    5. Parrot Skycontroller 2 USB Port Replacement: step 10, image 1 of 2 Parrot Skycontroller 2 USB Port Replacement: step 10, image 2 of 2
      • Remove the face plate by pulling up and out.
      Ask FixBot
    6. Parrot Skycontroller 2 USB Port Replacement: step 11, image 1 of 3 Parrot Skycontroller 2 USB Port Replacement: step 11, image 2 of 3 Parrot Skycontroller 2 USB Port Replacement: step 11, image 3 of 3
      • Position the device so that the top panel is flat down on the table. You should have access to the USB Port.
      • Desolder the two connection points in the back of the USB port.
      • Desolder the four wires in the back of the USB port.
      • Remove the the component from the board.
      • Excessive heat can damage the port, so do not apply the soldering iron to the component for too long.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 58
All Time: 1,332
