Shop the Holiday Gift Guide
Parrot Skycontroller 2 Power Port Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
56
All Time:
1,029
Comments: 8
8 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If using the Skycontroller 2 and you think the battery is not being charged or the controller is not receiving power, you might want to replace the power port. The power port supplies power to the battery in order to charge.
In order to replace the power port, first make sure the battery is disconnected and there is no power to the Skycontroller 2.
The power port will require soldering to remove, so check out our How to Solder and Desolder Connections guide to learn how to solder if you’re unfamiliar with the practice.
Tools
    1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: step 1, image 1 of 3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: step 1, image 2 of 3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: step 1, image 3 of 3
      • Flip the controller upside down.
      Ask FixBot
    2. Parrot Skycontroller 2 Power Port  Replacement: step 2, image 1 of 1
      • Remove one 9mm screw using a #4 flathead screwdriver.
      Ask FixBot
    3. Parrot Skycontroller 2 Power Port  Replacement: step 3, image 1 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 3, image 2 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 3, image 3 of 3
      • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
      • Remove the cover by pulling up and out.
      Ask FixBot
    4. Parrot Skycontroller 2 Power Port  Replacement: step 4, image 1 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 4, image 2 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 4, image 3 of 3
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling apart.
      Ask FixBot
    5. Parrot Skycontroller 2 Power Port  Replacement: step 5, image 1 of 2 Parrot Skycontroller 2 Power Port  Replacement: step 5, image 2 of 2
      • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
      • Some force may be required to separate the battery from it's brackets.
      Ask FixBot
    6. Parrot Skycontroller 2 Power Port  Replacement: step 6, image 1 of 1
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      Ask FixBot
    7. Parrot Skycontroller 2 Power Port  Replacement: step 7, image 1 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 7, image 2 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 7, image 3 of 3
      • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      Ask FixBot
    8. Parrot Skycontroller 2 Power Port  Replacement: step 8, image 1 of 1
      • Remove the battery compartment plate by pulling up and out.
      Ask FixBot
    9. Parrot Skycontroller 2 Power Port  Replacement: step 9, image 1 of 1
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      Ask FixBot
    10. Parrot Skycontroller 2 Power Port  Replacement: step 10, image 1 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 10, image 2 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 10, image 3 of 3
      • Remove the face plate by pulling up and out.
      Ask FixBot
    11. Parrot Skycontroller 2 Power Port  Replacement: step 11, image 1 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 11, image 2 of 3 Parrot Skycontroller 2 Power Port  Replacement: step 11, image 3 of 3
      • Make sure the controller is flat, then proceed to desolder the power port.
      • Desolder the four connection points surrounding the charging port.
      • Remove the power port from the controller.
      • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
      • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
      Ask FixBot
Author
with
Jonathan Epperly
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 56
All Time: 1,029
