Parrot Hydrofoil Orak Propellers Replacement
  1. Parrot Hydrofoil Orak Propellers Replacement, Propellers: step 1, image 1 of 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: step 1, image 2 of 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: step 1, image 3 of 3
    • Locate the propellers of the same angle, each diagonally across from each other.
    • Locate the propellers of the opposite angle, located diagonally across from each other.
    • Grip each white propeller firmly and pull up to remove.
    • Removing the propellers may require a decent use of force.
    • When replacing the propellers make sure to place the corresponding set in the right position, diagonally across from each other to ensure proper liftoff.
Jacob Munson
200 Reputation
1 Guide authored
Cal Poly, Team 20-2, Livingston Fall 2016 Member of Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 898
