Shop the Holiday Gift Guide
Panda CD-500 Disassembly
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
67
All Time:
561
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
      • Insert wisdom here.
      • Let's open it up.
      Ask FixBot
      • This is quite large.
      • I hope the glass top of the studio desk don't get in the way of viewing the pictures.
      • Anyhow.
      Ask FixBot
      • To open up the radio, you need to .. well, twirl away some screws.
      • Two screws are under the handle, four are on the back.
      • And a additional bunch on the (oof!) wet bottom.
      Ask FixBot
      • .. and a VERY deeply hidden Philips screw.
      • Break out your household mediumweight -- a long shaft Philips #1. You'll need it.
      Ask FixBot
      • With the case screw removed, you flip to the back of the .. thing.
      • Then, holding the bottom half (the half under the two white piece), push the top half up and away.
      • And ... it opens up, like a briefcase.
      Ask FixBot
      • Now with the device opened, we need to disconnect power.
      • Disconnect the four plugs on the "power board". Each of them is of a unique size, so you can't mix them up.
      • However, the two plugs (later three) on the "connector board" are practically identical, and are only different in the order of the wires connected.
      • Don't mix those up.
      Ask FixBot
      • The next step to separate the two halves involving disconnecting tentacles and umbilical cords the grounding line.
      • Fun fact -- the device has the power supplied through a two-prong plug, meaning there is no "true" GrouND.
      • This mystery is deepened by the fact that only the "CD board" have this "ground" cable at one of the screw posts.
      Ask FixBot
      • .. so the bottom half slides away.
      • Apparently the top half houses all the brain, since there are quite a few green PCBs and two large, dense boards.
      • We can make our lives easier by trying to remove the two white piece.
      • Apparently there is something holding them, since they refuse to move under slight tugs that aims to unseat them.
      • And those come from ... behind the handle?
      • So, how do you remove the handle?
      Ask FixBot
      • Well, if you flip to the side, you can see the joint of the handle.
      • And immediately next to the joint, is a "flap".
      • And if you depress this flap, this creates a channel, through which the handle can be slide backwards (and out of the hinge)
      • And THAT will give us access to this screw, which is required to remove the "white piece"s.
      Ask FixBot
      • Apparently all the "brain" is located on the top half. The boards are significantly more dense.
      • Next up we remove the "CD board".
      • Why the CD board?
      • I don't know. It will be a good question to think about while we pop the connectors and remove the screws.
      • Or wonder about what the ICs behind the heatsink/label actually do.
      • I bet the one behind the label is a storage unit, like ones in a flash drive.
      Ask FixBot
      • Next up we remove this "board with a cord".
      • But before we can do that, we need to disconnect THIS from the "main board".
      Ask FixBot
      • Turns out the white-ish "string" going from the coil to the board is actually made up of copper wires.
      • This is quite a rudimentary oscillator coil for the FM radio if you ask me.
      • There is a screw inside the "coupler" for the radio knob, and on that screw is some glue.
      Ask FixBot
      • Ah, because the USB port and the SD card adapter is blocked by it.
      • So now we remove those two little things.
      Ask FixBot
      • Then we would remove the ...
      • Huh?
      • Apparently the main board is trapped under the "tape board", so by the norm we will remove the "tape board" ...
      Ask FixBot
      • Apparently we are doing it wrong here, and we should instead focus on removing the front section from the top section.
      • So we will remove this L-bracket...
      • and this L-bracket.
      • And this screw on the first L-bracket.
      Ask FixBot
      • And then we will have to remove this switch, for the other wire on the connector is soldered to the board.
      Ask FixBot
      • The main board is now available for removal.
      • But before the motherboard is free, we need to turn to the cable-with-a-ring and remove that first.
      • Look at it. Water stains, oil stains, mineral deposits ...
      • The backside is quite ok, though.
      Ask FixBot
      • Then we go remove that tape drive.
      Ask FixBot
      • Let's pause here and examine that tape drive.
      • The buttons (fast forward, fast backward, play) control the location of the white gear.
      • The white gear then move to engage with different gears, which drive the two spindle at different speeds.
      Ask FixBot
      • So what is driving the white gear?
      • On the back, you will find the wheels and belts that drive it.
      • The white gear is attached to a armature that move into the different positions, while the elastic belt pick up any slack and accommodate for the length differences.
      Ask FixBot
      • With the tape drive gone, we can now access the front control-display bar.
      • Rid the ribbon cable, disconnect the connector and remove the button board.
      • Then remove the display board.
      Ask FixBot
Author
with
Xavier Jiang
1,886 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 67
All Time: 561
