Installing Panasonic Toughbook CF-29 Touchscreen
  1. Installing Panasonic Toughbook CF-29 Touchscreen, Battery: step 1, image 1 of 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Installing Panasonic Toughbook CF-29 Touchscreen: step 2, image 1 of 2 Installing Panasonic Toughbook CF-29 Touchscreen: step 2, image 2 of 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Installing Panasonic Toughbook CF-29 Touchscreen, Touchscreen: step 3, image 1 of 1
    • Remove the four hinge screws from the back of the computer.
  4. Installing Panasonic Toughbook CF-29 Touchscreen: step 4, image 1 of 2 Installing Panasonic Toughbook CF-29 Touchscreen: step 4, image 2 of 2
    • Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
    • Pry off the plastic strip which was previously held in place by the screws.
  5. Installing Panasonic Toughbook CF-29 Touchscreen: step 5, image 1 of 1
    • Remove the four hinge screws to allow the hinges to rotate up and move.
  6. Installing Panasonic Toughbook CF-29 Touchscreen: step 6, image 1 of 1
    • Remove 16 screws from the top of the closed laptop.
    • 12 Phillips size 1 screws
    • 2 Phillips size 0 screws
    • 2 Torx size 6 screws (T6)
  7. Installing Panasonic Toughbook CF-29 Touchscreen: step 7, image 1 of 1
    • Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
    • You will need to reapply the silicon adhesive during reassembly to ensure watertight seal.
  8. Installing Panasonic Toughbook CF-29 Touchscreen: step 8, image 1 of 1
    • Pull the top halve of the casing up revealing the inside of the screen
  9. Installing Panasonic Toughbook CF-29 Touchscreen: step 9, image 1 of 2 Installing Panasonic Toughbook CF-29 Touchscreen: step 9, image 2 of 2
    • The top half of the case can be removed by sliding the tabs out from under the hinges.
    • This makes unplugging the screen wiring much easier
  10. Installing Panasonic Toughbook CF-29 Touchscreen: step 10, image 1 of 1
    • There are 4 wires that need to be unplugged to remove the screen.
  11. Installing Panasonic Toughbook CF-29 Touchscreen: step 11, image 1 of 1
    • For the first wire, peel back the silver cover tape to reveal the connection.
  12. Installing Panasonic Toughbook CF-29 Touchscreen: step 12, image 1 of 1
    • Pull the wiring away from the connection to release it.
  13. Installing Panasonic Toughbook CF-29 Touchscreen: step 13, image 1 of 1
    • Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
    • Pull the wiring for each away from the connections to remove.
  14. Installing Panasonic Toughbook CF-29 Touchscreen: step 14, image 1 of 1
    • The 4th connection is already visible.
    • Depending on your model it might not be plugged into anything. If it is, remove it the same way the other 3 connections were removed.
  15. Installing Panasonic Toughbook CF-29 Touchscreen: step 15, image 1 of 2 Installing Panasonic Toughbook CF-29 Touchscreen: step 15, image 2 of 2
    • Using a plastic opening tool, lift the screen as shown from the case and pull free.
Dylan Bloom
373 Reputation
4 Guides authored
Cal Poly, Team 27-93, Amido Spring 2010 Member of Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Members
26 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 28
All Time: 17,098
