Panasonic PV-GS9 outercasing replacement
  1. Panasonic PV-GS9 outercasing replacement, Outer Casing: step 1, image 1 of 3 Panasonic PV-GS9 outercasing replacement, Outer Casing: step 1, image 2 of 3 Panasonic PV-GS9 outercasing replacement, Outer Casing: step 1, image 3 of 3
    • Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
  2. Panasonic PV-GS9 outercasing replacement: step 2, image 1 of 2 Panasonic PV-GS9 outercasing replacement: step 2, image 2 of 2
    • Open the tape compartment.
    • Using a #00 Phillips head screwdriver, remove the two 4.5mm screws from the camcorder.
  3. Panasonic PV-GS9 outercasing replacement: step 3, image 1 of 3 Panasonic PV-GS9 outercasing replacement: step 3, image 2 of 3 Panasonic PV-GS9 outercasing replacement: step 3, image 3 of 3
    • Use a plastic opening tool to remove the gray trim piece from top of the camcorder.
    • Take care when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 outercasing replacement: step 4, image 1 of 1
    • Rotate the camcorder so that the eye piece is facing you.
    • Remove the battery.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Be careful not to lose any screws whilst trying to remove them.
  5. Panasonic PV-GS9 outercasing replacement: step 5, image 1 of 2 Panasonic PV-GS9 outercasing replacement: step 5, image 2 of 2
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 outercasing replacement: step 6, image 1 of 2 Panasonic PV-GS9 outercasing replacement: step 6, image 2 of 2
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 outercasing replacement: step 7, image 1 of 1
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 outercasing replacement: step 8, image 1 of 2 Panasonic PV-GS9 outercasing replacement: step 8, image 2 of 2
    • Very carefully remove the front cover from the main body of the camcorder.
    • This should come apart with relative ease, however a plastic opening tool may help remove the panel.
    • There is a ribbon cable attached to the front panel and the camcorder body, so be careful not to pull that off when you remove this panel.
  9. Panasonic PV-GS9 outercasing replacement: step 9, image 1 of 2 Panasonic PV-GS9 outercasing replacement: step 9, image 2 of 2
    • Using your fingers, carefully pull the ribbon cable away from the logic board.
Trevor Johnson
31 Reputation
2 Guides authored
Cal Poly, Team 7-9, Maness Spring 2010 Member of Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,701
