Introduction
In order to repair the problems that may arise while using the Panasonic PV-GS9 you must disassemble the camcorder entirely. This will allow you to have three large pieces of the camcorder from which all the repairs can be made.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Open the tape compartment.
Using a #00 Phillips head screwdriver, remove the two 4.5mm screws from the camcorder.
Rotate the camcorder so that the eye piece is facing you.
Remove the battery.
Remove the four black 4.5mm screws, sitting behind the battery.
Remove the 5th screw to the right of the battery dock.
Rotate the camcorder so that the tape compartment is facing you. Remove the single 4.5mm black screw, which is above the hook for the hand strap.
It may help you during this step to undo the strap on one end.
Next, rotate the camcorder so that the lens is facing you. Remove the single 4.5mm black screw from the front panel.
Rotate the camcorder so that the bottom is facing towards you. Remove the single remaining 4.5mm black screw from the bottom.
Next, while still having the bottom of the camcorder facing you, remove the four silver 4.5mm screws from the body.
Open the LCD screen on the side of the camcorder.
Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
This should come apart with relative ease, however a plastic opening tool may help you remove this panel a little more easily.
