This teardown is in progress – Reload periodically to see the latest changes!
  1. Panasonic Lumix GX80/85 Teardown, Panasonic Lumix GX80/85 Teardown: step 1, image 1 of 3 Panasonic Lumix GX80/85 Teardown, Panasonic Lumix GX80/85 Teardown: step 1, image 2 of 3 Panasonic Lumix GX80/85 Teardown, Panasonic Lumix GX80/85 Teardown: step 1, image 3 of 3
    • I have dust particles underneath the sensor glass, so sensor swabs didn't help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process.
    • You can spot dust marks yourself best if you set the camera to the "A" mode at f/22 and take a picture of the sky
  2. Panasonic Lumix GX80/85 Teardown: step 2, image 1 of 1
    • Start with these two screws. Remember screw sizes and position, there are many different lengths used!
  3. Panasonic Lumix GX80/85 Teardown: step 3, image 1 of 3 Panasonic Lumix GX80/85 Teardown: step 3, image 2 of 3 Panasonic Lumix GX80/85 Teardown: step 3, image 3 of 3
    • remove the flash spring as shown and the four screws
  4. Panasonic Lumix GX80/85 Teardown: step 4, image 1 of 1
    • Remove this screw
  5. Panasonic Lumix GX80/85 Teardown: step 5, image 1 of 1
    • remove the bottom screws
  6. Panasonic Lumix GX80/85 Teardown: step 6, image 1 of 2 Panasonic Lumix GX80/85 Teardown: step 6, image 2 of 2
    • remove the backplate and remove the ribbon cables
  7. Panasonic Lumix GX80/85 Teardown: step 7, image 1 of 1
    • remove the 3 screws
  8. Panasonic Lumix GX80/85 Teardown: step 8, image 1 of 3 Panasonic Lumix GX80/85 Teardown: step 8, image 2 of 3 Panasonic Lumix GX80/85 Teardown: step 8, image 3 of 3
    • to remove the sensor more easily you can remove the top bar before
  9. Panasonic Lumix GX80/85 Teardown: step 9, image 1 of 1
    • Flash E.Capacitor removal
  10. Panasonic Lumix GX80/85 Teardown: step 10, image 1 of 2 Panasonic Lumix GX80/85 Teardown: step 10, image 2 of 2
    • Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets!
Andi
271 Reputation
1 Guide authored
15 Comments
Hello,
and what about Flange back adjustment? Did you solve it somehow?
Štěpán Karásek - Reply
Hi, what exactly do you mean? I managed to wipe the sensor clean, but correct reassembly is difficult. I might have missaligned the magnets holding the sensor and now the camera sometimes seems to focus very slow.
Andi -
How do you remove the top case unit or top bar?
Nigel - Reply
I need to access the SD card slot, as I am afraid something is stuck in the slot. The camera is giving messages “insert the card again”
vibishika - Reply
SD card is known as “delicate” one. Use MicroSD adapter with 2-3 plies of adhesive tape on “title side” over contacts. Plus two 5mm stripes near MicroSD slot. Insert adapter and use two stripes to secure your adapter to battery compartment walls. Never move adapter until you need to replace it. Then only use MicroSD cards with some adhesive tape stripe to pull the card from your new slot. Once properly contacted, adapter will avoid “insert SD card back” message on screen.
c64club - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 119
All Time: 5,487
