Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: step 1, image 1 of 1
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 2, image 1 of 3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 2, image 2 of 3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 2, image 3 of 3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 3, image 1 of 1
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 4, image 2 of 2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: step 5, image 1 of 1
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
Derrick Thompson
1,035 Reputation
5 Guides authored
Baylor, Team S2-G5, Johnson Spring 2018 Member of Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 209
