Installing Panasonic Lumix DMC-TZ5 AV port circuit board
  1. Installing Panasonic Lumix DMC-TZ5 AV port circuit board, Back Cover: step 1, image 1 of 1
    • Remove the battery and memory card from the device.
  2. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 2, image 1 of 1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 3, image 1 of 1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 4, image 1 of 1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 5, image 1 of 1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 6, image 1 of 2 Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 6, image 2 of 2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 7, image 1 of 1
    • Remove the back casing from the camera.
  8. Installing Panasonic Lumix DMC-TZ5 AV port circuit board, button board: step 8, image 1 of 2 Installing Panasonic Lumix DMC-TZ5 AV port circuit board, button board: step 8, image 2 of 2
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  9. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 9, image 1 of 1
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  10. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 10, image 1 of 2 Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 10, image 2 of 2
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  11. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 11, image 1 of 3 Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 11, image 2 of 3 Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 11, image 3 of 3
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
  12. Installing Panasonic Lumix DMC-TZ5 AV port circuit board, Camera Lens Assembly: step 12, image 1 of 1
    • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
  13. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 13, image 1 of 1
    • Remove the 3 screws holding the lens assembly in place.
    • The two screws on the left are 4.5mm with washers.
    • The single screw on the right is 4mm.
  14. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 14, image 1 of 1
    • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
  15. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 15, image 1 of 2 Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 15, image 2 of 2
    • Remove the entire assembly out of the casing.
    • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
  16. Installing Panasonic Lumix DMC-TZ5 AV port circuit board, AV port circuit board: step 16, image 1 of 1
    • Use the spudger to unclip the top ribbon cable from the circuit board.
  17. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 17, image 1 of 1
    • Remove the single 2mm screw in the bottom right corner of the circuit board
  18. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 18, image 1 of 2 Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 18, image 2 of 2
    • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
    • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
  19. Installing Panasonic Lumix DMC-TZ5 AV port circuit board: step 19, image 1 of 1
    • Take note of how the slots fit into the circuit board for easy replacement.
Kevin Lufkin
158 Reputation
2 Guides authored
Cal Poly, Team 9-21, Regan Fall 2010 Member of Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 8,420
