Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Battery: step 1, image 1 of 1
      • Move the switch on the battery door to the Open position.
      • The door will automatically swing open after you let it go.
      Ask FixBot
    2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 2, image 2 of 2
      • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
      • Keep your finger clear of the battery when it pops out.
      Ask FixBot
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Memory Card: step 3, image 1 of 1
      • Push the memory card in and let go.
      • The memory card will pop out slightly.
      • Pull out the memory card.
      Ask FixBot
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: step 4, image 1 of 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: step 4, image 2 of 2
      • Unscrew the small screws on the sides of the camera.
      • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
      Ask FixBot
    2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 5, image 2 of 2
      • Unscrew the three small screws on the bottom(#00P, 3.3mm).
      • The bottom will fall off.
      Ask FixBot
    3. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 6, image 1 of 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 6, image 2 of 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 6, image 3 of 3
      • Lift up the bottom back cover by prying the bottom edge with the spudger.
      • Gently lift up the back cover with your hand from the bottom to the top.
      Ask FixBot
    4. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: step 7, image 3 of 3
      • Lift the tabs on the ZIF connectors.
      • The ribbon cables should easily come out of the ZIF connectors.
      Ask FixBot
    1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: step 8, image 1 of 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: step 8, image 2 of 2
      • Gently wiggle out the top motherboard.
      • The buttons are hardwired into this logic board.
      Ask FixBot
Karissa
71 Reputation
8 Guides authored
Cal Poly, Team 6-23, Amido Spring 2012 Member of Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 1,303
