Panasonic KX-TGE233 Base Front Panel Assembly Replacement
    1. Panasonic KX-TGE233 Base Front Panel Assembly Replacement, Base Front Panel Assembly: step 1, image 1 of 1
      • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
      Ask FixBot
    2. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: step 2, image 1 of 1
      • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
      Ask FixBot
    3. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: step 3, image 1 of 1
      • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
      Ask FixBot
    4. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: step 4, image 1 of 1
      • With the screws removed, you can use a spudger to aid in removing the back from the device.
      • Levering the back by the spudger may break the tool!
      Ask FixBot
    5. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: step 5, image 1 of 1
      • With the back removed, we now have direct access to all other components in the main docking station.
      Ask FixBot
Jesse Satterwhite
688 Reputation
5 Guides authored
IUPUI, Team 2-2, Baechle Spring 2016 Member of IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 87
All Time: 838
