Panasonic KX-TGA600M Keypad Replacement
    1. Panasonic KX-TGA600M Keypad Replacement, Battery: step 1, image 1 of 2 Panasonic KX-TGA600M Keypad Replacement, Battery: step 1, image 2 of 2
      • On the back of the phone, remove battery cover.
      • Push down on the marked indentation and pull downwards.
      Ask FixBot
    2. Panasonic KX-TGA600M Keypad Replacement: step 2, image 1 of 1
      • Pull out to remove the battery.
      Ask FixBot
    1. Panasonic KX-TGA600M Keypad Replacement, Keypad: step 3, image 1 of 1
      • Once battery is removed, use the Phillips #00 screwdriver to remove the two silver screws at the bottom left and right corners on the back of the phone.
      Ask FixBot
    2. Panasonic KX-TGA600M Keypad Replacement: step 4, image 1 of 3 Panasonic KX-TGA600M Keypad Replacement: step 4, image 2 of 3 Panasonic KX-TGA600M Keypad Replacement: step 4, image 3 of 3
      • Pull the phone apart. The plastic opening tool may be needed.
      • The clear light piece will fall out, so make sure you place it next to the screws.
      Ask FixBot
    3. Panasonic KX-TGA600M Keypad Replacement: step 5, image 1 of 3 Panasonic KX-TGA600M Keypad Replacement: step 5, image 2 of 3 Panasonic KX-TGA600M Keypad Replacement: step 5, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the three screws holding the circuit-board in place.
      • The screws are located in the top right corner, bottom left corner, and bottom right corner.
      Ask FixBot
    4. Panasonic KX-TGA600M Keypad Replacement: step 6, image 1 of 1
      • Once the screws are out, remove the charging contacts beneath the two bottom corner screws.
      Ask FixBot
    5. Panasonic KX-TGA600M Keypad Replacement: step 7, image 1 of 1
      • Remove the circuit board.
      Ask FixBot
    6. Panasonic KX-TGA600M Keypad Replacement: step 8, image 1 of 1
      • Pull back the black silicone keypad.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Incomplete explanation with what materials to clean
asalmoom - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 27
All Time: 978
