Panasonic HC‑VX870 Hand Strap Replacement
  1. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: step 1, image 1 of 3 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: step 1, image 2 of 3 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: step 1, image 3 of 3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Hand Strap Replacement: step 2, image 1 of 2 Panasonic HC‑VX870 Hand Strap Replacement: step 2, image 2 of 2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Hand Strap Replacement, Record Button Mechanism: step 3, image 1 of 1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Hand Strap Replacement: step 4, image 1 of 1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Hand Strap Replacement: step 5, image 1 of 3 Panasonic HC‑VX870 Hand Strap Replacement: step 5, image 2 of 3 Panasonic HC‑VX870 Hand Strap Replacement: step 5, image 3 of 3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
  6. Panasonic HC‑VX870 Hand Strap Replacement, Hand Strap: step 6, image 1 of 1
    • Use the plastic opening tool to pry the little metal bar out of place in order to release one side of the hand strap.
  7. Panasonic HC‑VX870 Hand Strap Replacement: step 7, image 1 of 1
    • Unscrew the indicated screws and remove the piece it was holding in place.
  8. Panasonic HC‑VX870 Hand Strap Replacement: step 8, image 1 of 1
    • Repeat step 3 for this side of the strap.
  9. Panasonic HC‑VX870 Hand Strap Replacement: step 9, image 1 of 1
    • Pull the handle straps out of their holes to remove the strap.
Rebecca Maloney
501 Reputation
5 Guides authored
Cal Poly, Team 13-6, Banghart Winter 2017 Member of Cal Poly, Team 13-6, Banghart Winter 2017
CPSU-BANGHART-W17S13G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 560
