Panasonic DVD-RV31 Player Outer Case Replacement
  1. Panasonic DVD-RV31 Player Outer Case Replacement, Disk Tray Cover: step 1, image 1 of 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic DVD-RV31 Player Outer Case Replacement: step 2, image 1 of 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic DVD-RV31 Player Outer Case Replacement, Outer Case: step 3, image 1 of 2 Panasonic DVD-RV31 Player Outer Case Replacement, Outer Case: step 3, image 2 of 2
    • Remove 3 screws running along back edge of case cover.
    • Remove 2 screws from each side of case cover.
  4. Panasonic DVD-RV31 Player Outer Case Replacement: step 4, image 1 of 1
    • Grab edges of cover, pull outward slightly, and pull straight up.
Kevin
375 Reputation
8 Guides authored
Cal Poly, Team 18-20, Garner Spring 2011 Member of Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Members
11 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 13
All Time: 1,944
