Introduction
This repair guide will show you the best step by step procedure of how to replace your power button in your Panasonic ARC ES-LT3N. The process is fairly easy and you only need a one tool!
Lift up the rear casing from the bottom of the razor.
Lift up the rear casing from the sides of the razor.
Pull rear casing up and off razor.
Starting from the bottom, lift the front casing upward to separate the case from the device.
Continue to lift the device upward until you can pull the casing off.
