Canon PowerShot S80 Flash Replacement
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: step 1, image 1 of 2 Canon PowerShot S80 Flash Replacement, Outer Casing: step 1, image 2 of 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
    Ask FixBot
  2. Canon PowerShot S80 Flash Replacement: step 2, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 2, image 2 of 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
    Ask FixBot
  3. Canon PowerShot S80 Flash Replacement: step 3, image 1 of 3 Canon PowerShot S80 Flash Replacement: step 3, image 2 of 3 Canon PowerShot S80 Flash Replacement: step 3, image 3 of 3
    • Gently pull the front cover off of the camera.
    Ask FixBot
  4. Canon PowerShot S80 Flash Replacement: step 4, image 1 of 3 Canon PowerShot S80 Flash Replacement: step 4, image 2 of 3 Canon PowerShot S80 Flash Replacement: step 4, image 3 of 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
    Ask FixBot
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: step 5, image 1 of 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
    Ask FixBot
  6. Canon PowerShot S80 Flash Replacement: step 6, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 6, image 2 of 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
    Ask FixBot
  7. Canon PowerShot S80 Flash Replacement, Flash: step 7, image 1 of 1
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
    Ask FixBot
  8. Canon PowerShot S80 Flash Replacement: step 8, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
    Ask FixBot
  9. Canon PowerShot S80 Flash Replacement: step 9, image 1 of 1
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
    Ask FixBot
  10. Canon PowerShot S80 Flash Replacement: step 10, image 1 of 1
    • With a Phillips #00 Screwdriver, unscrew the flash board.
    Ask FixBot
  11. Canon PowerShot S80 Flash Replacement: step 11, image 1 of 1
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
    Ask FixBot
  12. Canon PowerShot S80 Flash Replacement: step 12, image 1 of 1
    • Lift the flash bulb unit upwards from the camera.
    Ask FixBot
  13. Canon PowerShot S80 Flash Replacement: step 13, image 1 of 2 Canon PowerShot S80 Flash Replacement: step 13, image 2 of 2
    • Lift the entire three-part flash assembly from the camera.
    Ask FixBot
BrettH
219 Reputation
5 Guides authored
Cal Poly, Team 19-5, Maness SU 2012 Member of Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Member
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 62
All Time: 4,047
