Introduction
This guide will teach you how to replace the control button on your Palm Zire m150. If you don't need to replace it, it will also teach you how to take the device apart in order to clean the control button.
Lift up the flap on the Palm Zire M150.
If you wish to remove it, gently lift up on the flap and pull horizontally. It should come off without an issue.
Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
Gently pull the top half and bottom half off the device apart using both hands so that it looks like the second photo.
This is the button that you are going to be replacing. Grab the grey button and pull it apart from the device.
The button is now off of the device. If you are cleaning it, use the compressed air or the alcohol wipe.
If installing a new button, throw away the one you just took off and snap the new one back on the white piece.
