Palm Zire 31 Screen Replacement
  1. Palm Zire 31 Screen Replacement, Case: step 1, image 1 of 1
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Screen Replacement: step 2, image 1 of 1
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Screen Replacement: step 3, image 1 of 1
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Screen Replacement: step 4, image 1 of 1
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Screen Replacement, Screen: step 5, image 1 of 1
    • Carefully pull back the brown cable holders and separate the screen from the motherboard.
Gabe
501 Reputation
5 Guides authored
Cal Poly, Team 5-21, Amido Winter 2011 Member of Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 2,504
