Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Using the spudger, pry the battery from where it is glued from the motherboard and observe that the leads are soldered on.
Heating up the soldering iron properly, place the wick against the solder bulbs and heat the solder until the solder wick sucks up the solder.
Solder the new battery's leads to the motherboard by taking the heated iron and heating the exposed wires of the leads and placing the solder in contact with the leads so the solder heats up and flows onto the leads.
Carefully pull back the brown cable holders and separate the screen from the motherboard.
