Palm Treo 755p Back Cover Replacement
  1. Palm Treo 755p Back Cover Replacement, Battery: step 1, image 1 of 3 Palm Treo 755p Back Cover Replacement, Battery: step 1, image 2 of 3 Palm Treo 755p Back Cover Replacement, Battery: step 1, image 3 of 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Back Cover Replacement: step 2, image 1 of 2 Palm Treo 755p Back Cover Replacement: step 2, image 2 of 2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Back Cover Replacement, Back Cover: step 3, image 1 of 2 Palm Treo 755p Back Cover Replacement, Back Cover: step 3, image 2 of 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Back Cover Replacement: step 4, image 1 of 1
    • WARNING: The top right red screw marked by the red circle has a warranty seal. Removing this seal will void your warranty.
    • Use the T5 screwdriver attachment to remove the 5 black back case screws marked by the red and yellow circles. These screws are 0.274 inches long.
    • Use the same T5 screwdriver attachment to remove the middle screw marked by the blue circle. It is shorter than the other screws at 0.121 inches in length.
  5. Palm Treo 755p Back Cover Replacement: step 5, image 1 of 2 Palm Treo 755p Back Cover Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • ATTENTION: Side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Back Cover Replacement: step 6, image 1 of 2 Palm Treo 755p Back Cover Replacement: step 6, image 2 of 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the yellow box.
    • WARNING: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Back Cover Replacement: step 7, image 1 of 3 Palm Treo 755p Back Cover Replacement: step 7, image 2 of 3 Palm Treo 755p Back Cover Replacement: step 7, image 3 of 3
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
Mike Shaw
601 Reputation
6 Guides authored
Cal Poly, Team 14-6, Forte Winter 2011 Member of Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,549
