Palm Treo 755p Antennna Replacement
  1. Palm Treo 755p Antennna Replacement, Battery: step 1, image 1 of 3 Palm Treo 755p Antennna Replacement, Battery: step 1, image 2 of 3 Palm Treo 755p Antennna Replacement, Battery: step 1, image 3 of 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Antennna Replacement: step 2, image 1 of 2 Palm Treo 755p Antennna Replacement: step 2, image 2 of 2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Antennna Replacement, Back Cover: step 3, image 1 of 2 Palm Treo 755p Antennna Replacement, Back Cover: step 3, image 2 of 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Antennna Replacement: step 4, image 1 of 1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Antennna Replacement: step 5, image 1 of 2 Palm Treo 755p Antennna Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Antennna Replacement: step 6, image 1 of 2 Palm Treo 755p Antennna Replacement: step 6, image 2 of 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Antennna Replacement: step 7, image 1 of 3 Palm Treo 755p Antennna Replacement: step 7, image 2 of 3 Palm Treo 755p Antennna Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  8. Palm Treo 755p Antennna Replacement, Antennna: step 8, image 1 of 1
    • The antenna is on the back half of the phone, and is marked by the yellow square.
  9. Palm Treo 755p Antennna Replacement: step 9, image 1 of 2 Palm Treo 755p Antennna Replacement: step 9, image 2 of 2
    • Press in the four black clips using the 025 Flathead screwdriver attachment to pop off the upper--back cover.
  10. Palm Treo 755p Antennna Replacement: step 10, image 1 of 1
    • Lift off the top of the back cover from the phone frame after undoing the clips.
  11. Palm Treo 755p Antennna Replacement: step 11, image 1 of 2 Palm Treo 755p Antennna Replacement: step 11, image 2 of 2
    • Gently pop off the antenna by pulling it away from the back cover.
Mike Shaw
601 Reputation
6 Guides authored
Cal Poly, Team 14-6, Forte Winter 2011 Member of Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,749
