Repairing Palm Treo 680 LCD Screen and Touch Screen
  1. Repairing Palm Treo 680 LCD Screen and Touch Screen, Battery: step 1, image 1 of 2 Repairing Palm Treo 680 LCD Screen and Touch Screen, Battery: step 1, image 2 of 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 2, image 1 of 1
    • Remove the battery by pulling it out towards you.
  3. Repairing Palm Treo 680 LCD Screen and Touch Screen, Back Panel: step 3, image 1 of 2 Repairing Palm Treo 680 LCD Screen and Touch Screen, Back Panel: step 3, image 2 of 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 4, image 1 of 2 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 4, image 2 of 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 5, image 1 of 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 6, image 1 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 6, image 2 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 6, image 3 of 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Repairing Palm Treo 680 LCD Screen and Touch Screen, LCD Screen and Touch Screen: step 7, image 1 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen, LCD Screen and Touch Screen: step 7, image 2 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen, LCD Screen and Touch Screen: step 7, image 3 of 3
    • Take the front the pannel and notice that the screen is attached by a piece of silver tape.
    • Using a pair of tweezers, carefully peel off this piece of silver tape.
    • Remove the screen from the front pannel.
  8. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 8, image 1 of 2 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 8, image 2 of 2
    • Obtain a small metal spudger and flip up the 2 tiny plastic flaps that hold the tiny orange ribbons in place.
    • Do the same thing for the other flap on the opposite side.
  9. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 9, image 1 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 9, image 2 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 9, image 3 of 3
    • Flip the screen over a 180 degrees and take off the metal piece that cushions the screen.
    • Flip the screen over another a 180 degrees and place pressure on the bottom ribbon (Where my left thumb is).
    • Slightly Pull apart the touch screen from the LCD screen by placing your thumbs where my thumbs are. DO NOT PULL THE TWO SCREENS COMPLETELY APART YET.
    • This part is tricky and might take some maneuvering and a little bit of force, but it is possible.
  10. Repairing Palm Treo 680 LCD Screen and Touch Screen: step 10, image 1 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 10, image 2 of 3 Repairing Palm Treo 680 LCD Screen and Touch Screen: step 10, image 3 of 3
    • Move your thumbs to the other corner of the screen and repeat the same procedure in step 9.
    • Carefully peel the touch screen away from the LCD screen.
    • Now you should have both the touch screen and LCD screen detached from one another.
Maiya123
51 Reputation
6 Guides authored
Cal Poly, Team 6-4, Maness Fall 2009 Member of Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 6,443
