Introduction
This is a guide that indicates how to replace a faulty microphone for the Palm Treo 680.
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
Remove the 27mm screw using the T6 Torx screwdriver.
Turn the phone so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
Separate the covers from the left side of the device as indicated in the picture.
Using a pair of tweezers, grasp the blue rubber microphone.
Pull the rubber microphone up and back to remove it.
Now you have successfully removed the microphone.
