Palm Treo 650 Motherboard Replacement
  1. Palm Treo 650 Motherboard Replacement, Battery and Stylus: step 1, image 1 of 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Motherboard Replacement: step 2, image 1 of 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Motherboard Replacement: step 3, image 1 of 2 Palm Treo 650 Motherboard Replacement: step 3, image 2 of 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Motherboard Replacement, Case: step 4, image 1 of 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Motherboard Replacement: step 5, image 1 of 2 Palm Treo 650 Motherboard Replacement: step 5, image 2 of 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Motherboard Replacement: step 6, image 1 of 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Motherboard Replacement: step 7, image 1 of 2 Palm Treo 650 Motherboard Replacement: step 7, image 2 of 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Motherboard Replacement, Motherboard: step 8, image 1 of 3 Palm Treo 650 Motherboard Replacement, Motherboard: step 8, image 2 of 3 Palm Treo 650 Motherboard Replacement, Motherboard: step 8, image 3 of 3
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
    • Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
  9. Palm Treo 650 Motherboard Replacement: step 9, image 1 of 2 Palm Treo 650 Motherboard Replacement: step 9, image 2 of 2
    • Pull off the mother board.
    • Install replacement or repaired motherboard, reversing steps above.
mmedrano
95 Reputation
2 Guides authored
Cal Poly, Team 19-3, Maness Fall 2009 Member of Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 4,267
