Installing Palm Treo 650 Earphone
  1. Installing Palm Treo 650 Earphone, Battery and Stylus: step 1, image 1 of 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Installing Palm Treo 650 Earphone: step 2, image 1 of 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Installing Palm Treo 650 Earphone: step 3, image 1 of 2 Installing Palm Treo 650 Earphone: step 3, image 2 of 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Installing Palm Treo 650 Earphone, Case: step 4, image 1 of 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Installing Palm Treo 650 Earphone: step 5, image 1 of 2 Installing Palm Treo 650 Earphone: step 5, image 2 of 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Installing Palm Treo 650 Earphone: step 6, image 1 of 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Installing Palm Treo 650 Earphone: step 7, image 1 of 2 Installing Palm Treo 650 Earphone: step 7, image 2 of 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Installing Palm Treo 650 Earphone, Motherboard: step 8, image 1 of 3 Installing Palm Treo 650 Earphone, Motherboard: step 8, image 2 of 3 Installing Palm Treo 650 Earphone, Motherboard: step 8, image 3 of 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Installing Palm Treo 650 Earphone: step 9, image 1 of 2 Installing Palm Treo 650 Earphone: step 9, image 2 of 2
    • Pull off the motherboard.
  10. Installing Palm Treo 650 Earphone, Earphone: step 10, image 1 of 3 Installing Palm Treo 650 Earphone, Earphone: step 10, image 2 of 3 Installing Palm Treo 650 Earphone, Earphone: step 10, image 3 of 3
    • Pull out the earphone by grabbing the black rubber piece.
cgood
122 Reputation
7 Guides authored
Cal Poly, Team 19-3, Maness Fall 2009 Member of Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,989
