Introduction
Need to access the interior. Here's how to take off the case to do that.
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Remove the small round rubber cover on the back of the phone located immediately below the antenna.
Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver.
Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
Pull out antenna.
