Palm Treo 650 Case Replacement
  1. Palm Treo 650 Case Replacement, Battery and Stylus: step 1, image 1 of 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Case Replacement: step 2, image 1 of 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Case Replacement: step 3, image 1 of 2 Palm Treo 650 Case Replacement: step 3, image 2 of 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Case Replacement, Case: step 4, image 1 of 1
    • Remove the round rubber cover on the back of the phone located immediately below the antenna.
    • This will uncover a screw that will be removed in the next step.
  5. Palm Treo 650 Case Replacement: step 5, image 1 of 2 Palm Treo 650 Case Replacement: step 5, image 2 of 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate using a Phillips #00 screwdriver.
  6. Palm Treo 650 Case Replacement: step 6, image 1 of 1
    • Remove the antenna.
  7. Palm Treo 650 Case Replacement: step 7, image 1 of 2 Palm Treo 650 Case Replacement: step 7, image 2 of 2
    • Pry the back cover off using an opening tool.
    • The back cover is attached by several small clips on the inside.
mmedrano
95 Reputation
2 Guides authored
Cal Poly, Team 19-3, Maness Fall 2009 Member of Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 3,087
