Introduction
Need to access the interior. Here's how to take off the case to do that.
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Remove the small round rubber cover on the back of the phone located immediately below the antenna.
Remove the six 6.9 mm screws around the back plate with a T5 Torx screwdriver.
Remove the single 9.8 mm screw next to the antennae on the back plate using a Phillips #00 screwdriver.
