Repairing Palm Treo 600 Screen
  1. Repairing Palm Treo 600 Screen, Back Case: step 1, image 1 of 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Repairing Palm Treo 600 Screen: step 2, image 1 of 2 Repairing Palm Treo 600 Screen: step 2, image 2 of 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Repairing Palm Treo 600 Screen: step 3, image 1 of 2 Repairing Palm Treo 600 Screen: step 3, image 2 of 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Repairing Palm Treo 600 Screen, Front Case: step 4, image 1 of 2 Repairing Palm Treo 600 Screen, Front Case: step 4, image 2 of 2
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Repairing Palm Treo 600 Screen, Screen: step 5, image 1 of 1
    • The screen is connected to the phone with an orange data cable.
    • Slide the spudger as close to the connection as possible.
    • Gently pull the spudger up and the cable should come out of the socket.
  6. Repairing Palm Treo 600 Screen: step 6, image 1 of 2 Repairing Palm Treo 600 Screen: step 6, image 2 of 2
    • Once the cable is unplugged, you can remove the screen from the body.
Clement Poisson
24 Reputation
7 Guides authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
16 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,197
